Not a major release.
2018-01-12: What's New in HP 3D Scan Version 5.4.0
Misc:
* Much faster OBJ, STL, and PLY export of very big meshes
* Improvements to translation of text in various languages
* Minor improvements to hardware handling
Bugfix:
* Several minor bugfixes
David 5.4 Is out
Re: David 5.4 Is out
Hi micr0. Thank you for notification. I think HP can make major enhancment by:Micr0 wrote: ↑27 Mar 2018, 23:40 Not a major release.
Misc:
Bugfix:
Adding marker method for alignment.
Changing calibration method. But add a new method beside current one. Not omite current fast method.
Work on processing of software. With large scan, we need big RAM sources. Also working with grouped meshes are very slow and disturbing.
I'd second bigbomber's suggestion, still, we need some basic improvements like being able to "add to selection" in shape fusion environment, heck, you cant even hold ctrl or shift and add to selection when you want to cleanup. add customizable shortcuts to the list.bigbomber wrote: ↑29 Mar 2018, 08:56Hi micr0. Thank you for notification. I think HP can make major enhancment by:Micr0 wrote: ↑27 Mar 2018, 23:40 Not a major release.
Misc:
Bugfix:
I wish I could remove unwanted part of the scan. Is it possible now? I mean select and delete triangles, align and fuse only desired patches.
Yes. It has been possible from very ealier versions.
Select unwanted mesh part and click on red x sign on upper left window.it will delete only selected portion of a single or grouped or even fused mesh.
Thanks Micro! That's great. I'll stop exporting stl and re-import them..
Never realised I had a cleaning tab!
Sorry.
Thanks BigBomber
I thinks it's the second time I mismatch names. Getting older.![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Thanks BigBomber
![Smile :-)](./images/smilies/icon_e_smile.gif)
The feature I really want to see is a Fu**ing undo button. Nothing like accidentally deleting part of a scan you want to keep and not having an undo to bring it back. Reload and there go all your unsaved changes.
