Flexscan3D is now free!
Post by Alonso »
Greetings everyone!
In case you missed this (probably have!)
This amazing software is now free!
https://www.polyga.com/flexscan3d/#download
And yes, this is the full suite of tools that was once only available with the purchase of a 3d scanner from Polyga.
Here are some technical specs with a list of recommended cameras to use.
https://www.polyga.com/technical-specifications/
I strongly recommend using Basler or Point Grey cams as they have optimized drivers included with Flexscan3D and enable HDR scanning.
Cameras using directshow drivers (Imaging Source and other brands) are "ok" but lack HDR scanning support and generally have slower scan capture times.
Enjoy!
Re: Flexscan3D is now free!
Has anyone written and or posted a detailed how to on modifying the PF1500/HF60 projector?
Post by Alonso »
greenskynet wrote: 27 May 2024, 05:16 Snip
Hi Nasr,
I've been well. Just busy with life ATM.
I would like to point out to everyone, for full transparency, that the "Modified" Flexscan3D software being SOLD is not endorsed or supported by Polyga.
Polyga has no affiliation with greeskynet/Nasr in any way.
Fly
Post by Fly »
Scanning with gray points works really well. This is my scan test. https://youtu.be/rebcpZ1Nw1A?si=z9Exi7bYauVsqMOB
Fly wrote: 14 Jun 2024, 08:49 Scanning with gray points works really well. This is my scan test. https://youtu.be/rebcpZ1Nw1A?si=z9Exi7bYauVsqMOB Image_1718208328801.pngImage_1718208319660.png
Nice scans. Which point gray cameras (Lenses) and which projector?
Is that a boars skull?
Fly
Post by Fly »
used is POINT GREY GS3 U3 91s.The projector is a modified DLP1080p home projector.50mm lens
I revive this topic.
I would like to know if there's anybody using basler cameras out there, with the unmodified flexscan.
Post by Alonso »
I am. What would you like to know?
Hi Alonso,
I was wondering how easy is to setup a couple of Basler ACE/ACE2
Post by Alonso »
What model number are your cameras?
I use acA2040-55um cams and they are a breeze to setup.
