Vanishing Scanning Spray
Re: Vanishing Scanning Spray
Post by OBNRacerMan » 24 Nov 2019, 20:48
martan wrote:
08 Nov 2019, 11:48
... for 300 Euros / 12pcs ...
It’s a pity that this is only slightly less than my monthly salary ... :(
Mr_Lafuente
Post by Mr_Lafuente » 15 Jan 2020, 22:04
I use PlastiDip. Its easy to peal off and its not expensive:
https://youtu.be/sIUbG4f2tMw?t=86
Post by Micr0 » 16 Jan 2020, 01:00
Mr_Lafuente wrote:
15 Jan 2020, 22:04
The problem with plastidip is that it's thick and distorts the dimensions and sharp feature of the part you are trying to scan. Ideally with scanning spray you want a very light dusting.
Post by OBNRacerMan » 16 Jan 2020, 16:54
Micr0 wrote:
16 Jan 2020, 01:00
I completely agree - the other day I had to scan a large semi-precious stone for the ring (it has a not quite standard shape, and it was very difficult to measure everything exactly), and due to the absence of any spray, I smeared it with a white “corrector for correction text on paper "- at least the form turned out (which I needed), and the edges are poorly visible.
Mr_Lafuente
Post by Mr_Lafuente » 24 Apr 2020, 16:21
I just found this thread on Reddit:
https://www.reddit.com/r/3DScanning/com ... d/d1fl4lp/
kodex1717 seem to have tried some diferent ones and said about this Spotcheck SKD-S2 Developer by Magnaflux, wich surprisely is very cheap in my country. I paid 15 USD for a can. Will try it next week.
Post by Micr0 » 26 Apr 2020, 03:53
Mr_Lafuente wrote:
24 Apr 2020, 16:21
That"s the stuff I use. Works well. don't spray it on too heavy. it's easy to think you haven't sprayed enough, spray more and realize when it dries that you oversprayed. It can be then a bit difficult to get it completely off. It tends to like to stay in the nooks and cracks.
ibhurln
Post by ibhurln » 24 Jun 2020, 09:54
ive tried anti-fungal/athlete's foot spray that works really well for smaller scans and is cheap.
For larger scans, i use an automotive style HVLP paint gun with a mixture of baby powder and rubbing alcohol.
The alcohol evaporates immediately leaving the fine white powder behind. It only takes a light dusting to get great scans.
The only downside is washing or blowing the powder off when you are done.
