Is the camera and lens combination wrong?
kth307000
Post by kth307000 »
Hello
I bought cameras and lenses with a lot of help from this forum.
viewtopic.php?f=2&t=2023&start=50
https://aliexpress.ru/item/32864044502. ... 1595001424
https://aliexpress.ru/item/32713339739. ... 1595001424
However, it is out of focus as seen in the picture.
No matter how much you turn the lens, clear images are not displayed.
Is the lens not suitable for the application?
Or do you need other settings?
Please help.
Re: Is the camera and lens combination wrong?
I do not understand why the problems are occurring. When I had these cameras, they docked perfectly with such lenses and worked.
YW500U3 with ZLKC lens
Post by bigbomber »
kth307000 wrote: 28 Jul 2020, 05:15 Hello
Please help.
investigate to know if your lens is C or CS mount. and the same for your camera.
kth307000
Post by kth307000 »
bigbomber wrote: 29 Jul 2020, 05:20
Please help.
I purchased the camera and lens with c mount, but in another reply, I received an answer saying that I could adjust the bolt of the camera to fit it.
viewtopic.php?f=5&t=2097&start=30#p3893
I haven't tried it because I don't have any tools yet, but I have plans to use the adapter ring if it fails after trying.
Thank you for your precious answer.
