Questions about David scanner sls-3
Posted: 27 Oct 2020, 18:30
hi,
i have a david scanner sls-3 and i have some question about:
1) May i have a particular mount to substitute the projector Acer k132 with an Optoma ml750e on the david scan sls-3 system? In detail: may i need a socket with a partucular mount angle for projector Optoma ml750e on the bar?
2) Is it normal that the scanning process sometime is slow and sometimes is fast (using HP 3D Scan Software Pro v5)? Is It related to calibration process (good/not goot) ? Ps: I have a fast notebook (with i7 th gen with 8 core,8gb ram,ssd, gtx 1050,usb3)
3) I noticed that in some posts you suggest to see the debug panel to undestand if the projector/camera are correctly
configured. Could you explain me what are the perfect angles that i must to have?
4) How can i test if the David Scan calibration panel is perfect or damaged/curved?
5) I use 2 default sls-3 cameras ( "DAVID-CAM-4-M") with Computar lens. (8",12" ,25") and the projector Optoma ml750e to scan litle objects max 12cm. What do you suggest to increase the scan details? (What it is better to change?)
6) (Example) If i try to scan a cube, i'm in trouble with faces allignments. How to solve? Markers? If so, where can i found them or how can i build them?
Thank you for your time!
