3D scanning - high resolution for small objects
gkrywusha
Re: 3D scanning - high resolution for small objects
Post by gkrywusha »
Hey all,
It's been awhile for me since the David forum and I just found this one.
In regard to scanning small objects, that's what I'm doing now. Mostly 32mm miniatures for gaming and such.
I still use HP Scan/David 5. Projector is Acer K132 with am Imaging Source DMK 23UX236 using Computar lens.
In order to achieve a decent quality I use a 4+ Vivitar attached to the front of the projector via a 3d printed adapter.
Here's a base 32mm mini with base fusion and no cleanup...
gkrywusha wrote: 14 Mar 2021, 06:32 Hey all,
Very nice.
What is the focal length of your lenses?
I have tried magnifying lenses on the projector and and always got significant distortion in the scan data. You don't seem to have that problem.
gkrywusha
Post by gkrywusha »
Here's the one I use...
computar M1214-MP2 C-Mount 12mm Fixed Lens
This is sold on many online stores. I bought my 5 years ago from B&H.
https://www.bhphotovideo.com/c/product/ ... O_EALw_wcB
The sites say Focal Length is 12mm. As most of my scans are between 40-120mm, I have a table tripod set at about 1 foot away from the turntable. The projector with the 4+ adapter seems to have enough focus to work at this distance.
I am rebuilding now to add the second camera, create a blackbox with Black 3.0 paint and such. Hardest is redesigning the projector wedge for the addition of dovetail use.
Let me know if you need any more info.
gkrywusha
Post by gkrywusha »
This is the set of lenses I use for the projector. They aren't available (this brand) on Amazon at this point. But there are others.
https://www.amazon.com/gp/product/B004E ... UTF8&psc=1
Having them at 37mm made them the right size to create an appropriate adapter for the projector - K132.
letstry001
Post by letstry001 »
Hi, i have some questions about small objet scan...
1) which scan configuration panels are you using to scan very smal objects (es: 0.5-2 cm)?
2) what vertical angle do you use between the camera and the projector? May i need to calculate it ?
Thank you
NARMELLA
Post by NARMELLA »
letstry001 wrote: 01 Apr 2021, 13:25 Hi, i have some questions about small objet scan...
Thank you
Two main parameters are important for scanning components ( any size of components).
The size of projected image on a component and the size of the image that is taken for use in the software.
Both must be proportionate.
The image projected on the component should be as close to the size of the component.
The same goes for the image taken.
After all you will find the right size of colibration panel.
About vertical angle : it completely depends to your hardware and the software that you want to use. ( dls has minimum triangulation angle and i use it.)
Narmella.
Post by bigbomber »
NARMELLA wrote: 02 Apr 2021, 07:46 Two main parameters are important for scanning components ( any size of components).
Narmella.
Hi
what is dls?
Single lens digital reflex?
HP 3D scan, LG PF50, LG PF1500 David Calibration panels, Melamine panels, DIY rotary table. RangeVision DIY: 2x DahengMer630, 2X12 and 2X16 mm 5Mp ZK lenses, RV turntable
Hi
what is dls?
David Laser Scanner
letstry001
Thank you
Narmella.
Sorry but...what is the dls minimum vertical triangulation angle ?
