Installation was easy. I had some warning since I host Rangevision in the same computer, and I had to change something to the directshow.
Don't ask me what, since I just followed the instructions.
Now I'm going to print a chessboard to roughly test the calibration procedure.
It's a new exciting journey!
mading wrote: ↑21 Jan 2021, 19:52
... I had some warning since I host Rangevision in the same computer, and I had to change something to the directshow...
Hi. As far as I understand, since you have an RV, then you also have Daheng cameras - they are still not visible in the list of the "updated" version of FS3D as in the old versions?
Today I started with some tests.
Calibration was fast, although I was not super precise.
A chessboard printed with an inkjet and glued to a particleboard. Just a try.
I still have some issues scanning, as I reported to Polyga: no mesh is created.
I suspect the projector: the LG PF50ks is seen as 1280*720.
Checked the depth filter, but it's not the cause of the missing data.
I definetely prefer flat calibration panels, and don't understand why David insisted so much in the angle panels.
That made sense with one camera. But a pain in the axx for two.
OBNRacerMan wrote: ↑22 Jan 2021, 07:51
Hi OBNRacerMan.
Not yet tested, although when I asked them (see old posts) they says that Daheng was too a small manufacturer.
I'll let you know ASAP.
Hi there,
I started this topic since today I installed and run Flexscan3D with my couple of IS 23UX236, thanks to the kind and fast support of Polyga.
Hi
How do you use IS cameras with Flex? As I know it only supports Pointgrey Cameras.
