Page 4 of 5
Re: Flexscan3D with IS cameras
Posted: 27 Jan 2021, 21:27
Great job Martan!
Posted: 28 Jan 2021, 14:18
mading wrote: โ27 Jan 2021, 21:27
Great job Martan!
Nice.
Do you have a triumph or BSA to go with that Amal?
Keep us posted with your thoughts.
Posted: 28 Jan 2021, 18:57
by martan
Tried a bit more and I some scans are very striped.
Tried different shutterspeeds from 1/60 down to 1/27. No change.
Any Ideas?
These scans are without any changes in the settings at all.
Just pressed the scan button a few times and the scans turns out good sometimes and bad sometimes.
The carburettor belongs to a friend with a few old english motorcycles. One is a BSA Rocket I think.
Posted: 28 Jan 2021, 21:48
I got similar defects.
Tried once, but got less problems over 160 (ms?)
Posted: 28 Jan 2021, 21:49
Make sure you are not shaking the table with the carb on it or the cameras.
Posted: 30 Jan 2021, 07:05
by martan
@Mading, What setting are you referring to ? The 160ms.
@ยต - nothing moves
Posted: 30 Jan 2021, 07:40
martan wrote: โ30 Jan 2021, 07:05
@Mading, What are you referring to ? The 160ms
The number you see when you select "advanced" Above the cameras.
I got no data unless I increase above 160 (or whatever I don't remember).
If you press "Estimate" Gives you the theorethical syncro delay (I guess). Gave me 60: no data, only occasionally. If I increase the parameter data progressively appear.
Posted: 30 Jan 2021, 14:48
by martan
Thanks Mading!
The text is missing on those figures. Seen them in the manual.
Button "Estimate" gav me different numbers frpm 50 to 170. Can't say I saw any effect.
Made a new calibration panel and was a bit more thorough when calibrating and now it seems to work.
Any one had the energy to look at a DIY rotary table solution?
Posted: 30 Jan 2021, 15:04
by Alonso
martan wrote: โ30 Jan 2021, 14:48
I'm researching that right now. No clue when I'd have something actually useful to share though...
Posted: 31 Jan 2021, 13:28
by martan
@Alonso
What is yor aproach to the rotary table?
I see three scenarios:
Use one of the existing plugins and new Arduino code
Make new plugin from example
Make new plugin from example AND new Arduino code
