Structured light 3d scanner with Daheng cameras (MER2-630-60U3M)?
Re: Structured light 3d scanner with Daheng cameras (MER2-630-60U3M)?
What is the going price for a Range vision license?
Around 350€
You find it in AliExpress Russian.
https://m.aliexpress.ru/item/1005001410 ... 577&gclid=
I'm not sure if buying Rangevision DIY kit from Aliexpress is available in other countries.
P.S. In Russia, this kit can be supplemented with an automatic rotary table.
Yes. For buying you will have to contact them by means of a Telegram chat: https://t.me/c/1231403401/1597
Although the automatic turntable is perfect and reasonably priced (250€) I was told that a ConXim turntable will perform the same tasks.
The problem of the "alien" turntable is that the ComXim manufacturer does not directly produce tables that have "only" USB control (they make such to order only for RVs). And of the rest of their USB models, some models with a WiFi remote control ( which are quite expensive)
a bigger one, with IR remote, bluetooth, ecc...
https://it.aliexpress.com/item/33059642 ... 91253c0f-3
of course you can use an ESP32 microcontroller and have it controlled by wifi from your domotic system (such as home assistant)..
(not tried yet, but if somebody did it feel free to share )
