Shining 3D Scanner Question
ganuv30
Post by ganuv30 »
HI,
I own a shining 3d dental scanner, and I was wondering if I can find a program that can be used with this scanner for scanning regular object's besides the default intraoral scan program?
Re: Shining 3D Scanner Question
ganuv30 wrote: 12 Aug 2022, 19:09 HI,
find your question in the following thread
viewtopic.php?f=16&t=2305
Is it a reply or an advertisement?
greenskynet wrote: 13 Aug 2022, 10:01 find your question in the following thread
Getting to your question, I once had a friend tried to scan a 30 cm object with an intraoral scanner.
As I supposed, it was not good for big stuff.
It missed the overall shape, being good ony for small details.
Like measuring a wall lenght with a micrometer or a caliper.
mading wrote: 16 Aug 2022, 11:35 Is it a reply or an advertisement?
Like measuring a wall length with a micrometer or a caliper.
I suppose that dental scanner are designed to scan an object automatically by one click and you can't control scanning process and ...
I think he is asking if he can bypass this automatic scanning process and use his hardware to scan other small objects with dimension smaller than 100mm, like jewellery and ...
surely you can't use a dental scanner for scanning a 1 meter object, unless you make some changes on hardware too.
Is it an intraoral scanner or not?
Can you show which model are you referring to?
ganuv30
Post by ganuv30 »
yes, it is an intraoral scanner
ganuv30
Post by ganuv30 »
For some reason I can't upload the image here
ganuv30
Post by ganuv30 »
ganuv30
Post by ganuv30 »
I managed to scan a few items with the dental program, but it is extremely difficult to catch full items. It's a shame to buy another $10K+ scanner, I'm pretty sure that there might be another solution for using this scanner for scanning regular objects
