David 5 VS Flexscan3d
erapip
Post by erapip »
Recently im trying to compare the softwares using exactly the same setup to see the differences. It looks thad David has little problem with reflective materials (even without spray) than Flex.
The quality of Single scan in Flex is still superior.
Anyone has tested them?
THNX!
Re: David 5 VS Flexscan3d
Are you using both software with the same hardware? Does LMI offer a demo of flex that you can use with your own hardware as David does?
erapip
Post by erapip »
Yes, same hardware and setup. Flex is 3.1.7 that allow to costumade.
spark
Post by spark »
hi, is flexscan working together with is cameras? i guess they are speciallized to the grasshopper?
Where to get flexscan 3.1.7 - is there a demo available?
regards, spark
spark
Post by spark »
Is there any possibility to test the early version of Flexscan?
Before i choosed david you could find some informations about flexscan with customized hardware (even dslr), but then they switched over to specialized hardware due to quality and implementation issues. afterwards is was getting silent around flexscan as customized solution.
(my impression)
hope (HP)david leaves the choice of hardware open in future versions!
So the current version (3.2.2) won't work with user supplied hardware? I was hoping to try it out and see how it compared.
spark
Post by spark »
dont know in detail, but try to find out if the is cameras are supported.
i read in the past that they were not...
regards, spark
spark
Post by spark »
FlexScan3D* optimizes the 3D scanning workflow––from capturing scans, to building scans into a digital 3D model, to cleaning the model with advanced post-processing capabilities.
* FlexScan3D software is only sold with our HDI scanner hardware.
http://lmi3d.com/products/hdi/flexscan3d
NARMELLA
Post by NARMELLA »
erapip wrote: 10 Mar 2017, 19:57 Yes, same hardware and setup. Flex is 3.1.7 that allow to costumade.
What kind of camera(s) did you use ?
erapip
Post by erapip »
Hello NARMELLA,
I'm using UI-1480-C, camera FUJINON HF12.5HA-1B (1:1.4/12.5mm). In MAX resolution the fps are low but for me is OK.
Regards,
Erald
