Grainy Scan troubleshooting
Posted: 02 Jun 2017, 17:58
Hello everybody,
I've built my David SLS using custom hardware, IS DMK23U236 Camera, Computar 12mm lens, ACER P1283i projector, I could almost eliminated waves and lines in scan, using recommended procedure to sync projector and camera refresh rates, however I'm faced with scans with grainy surface quality, as an example, please check the quality of the shampoo bottle scan, the part is molded plastic but the surface quality is similar to cast iron with grainy finish in David and Geomagic viewer. I Know I can post process the stl to get smoother results, but I'm looking for ways to eliminate the grainy finish in scan mode. I'd appreciate your comments.
