Hello,
I'm looking for software that will be able to import panoramas with coordinates and create a virtual tour. So far, I've been using 3D Vista and Marzipano, and I have to do the linking between viewpoints manually. The coordinates are there because the panoramas come from a scanner.
Panorama after 3D scanning
Re: Panorama after 3D scanning
btw, if your scanner produces an e57 file .. then you can use our web uploader : quato.xyz/uploadcrumb wrote: ↑07 May 2024, 07:30 Hello,
It gives you a preview and some stats from the e57 file .. then you can chose to upload panorama images.
NB. does not upload the points .. which is faster and less data - you get a pano tour, but no pointcloud.
If your panos overlap well .. then you can pick points in space, and do 3D modelling :] :
http://pho.tiyuti.com/list/tu9selv8sc
gord
