Meshroom has halted
Write here about everything related to photogrammetry
DanielHowden
Meshroom has halted
Post by DanielHowden »
Meshroom seems to have stopped on DepthMap node. To be honest, I'm not sure what to try as I can't see an actual error.
Thanks, Daniel.
Code: Select all
Program called with the following parameters:
 * downscale = 2
 * exportIntermediateResults = 0
 * imagesFolder = "C:/Users/danie/OneDrive/Desktop/MeshroomCache/PrepareDenseScene/b2406cba29b7bca9c1b7f7b20977f829d551ca90"
 * input = "C:/Users/danie/OneDrive/Desktop/MeshroomCache/StructureFromMotion/fd2c7716637715655dd599e881a3611ee36cd747/sfm.abc"
 * maxViewAngle = 70
 * minViewAngle = 2
 * nbGPUs = 0
 * output = "C:/Users/danie/OneDrive/Desktop/MeshroomCache/DepthMap/85781bf56f678144ed9520f6411463441b5bc977"
 * rangeSize = 3
 * rangeStart = 39
 * refineGammaC = 15.5
 * refineGammaP = 8
 * refineMaxTCams = 6
 * refineNDepthsToRefine = 31
 * refineNSamplesHalf = 150
 * refineNiters = 100
 * refineSigma = 15
 * refineUseTcOrRcPixSize = 0
 * refineWSH = 3
 * sgmGammaC = 5.5
 * sgmGammaP = 8
 * sgmMaxTCams = 10
 * sgmWSH = 4
 * verboseLevel = "info"
[20:49:48.500891][info] CUDA-Enabled GPU.
Device information:
	- id:                      0
	- name:                    NVIDIA GeForce GTX 970
	- compute capability:      5.2
	- total device memory:     4095 MB
	- device memory available: 3369 MB
	- per-block shared memory: 49152
	- warp size:               32
	- max threads per block:   1024
	- max threads per SM(X):   2048
	- max block sizes:         {1024,1024,64}
	- max grid sizes:          {2147483647,65535,65535}
	- max 2D array texture:    {65536,65536}
	- max 3D array texture:    {4096,4096,4096}
	- max 2D linear texture:   {65536,65536,1048544}
	- max 2D layered texture:  {16384,16384,2048}
	- number of SM(x)s:        13
	- registers per SM(x):     65536
	- registers per block:     65536
	- concurrent kernels:      yes
	- mapping host memory:     yes
	- unified addressing:      yes
	- texture alignment:       512 byte
	- pitch alignment:         32 byte
[20:49:48.602884][info] Supported CUDA-Enabled GPU detected.
[20:50:12.806422][info] Found 1 image dimension(s):
[20:50:12.806422][info] 	- [3840x2160]
[20:50:13.481382][info] Overall maximum dimension: [3840x2160]
[20:50:13.482341][info] Create depth maps.
[20:50:13.482341][info] # GPU devices: 1, # CPU threads: 4
[20:50:13.482341][info] Plane sweeping parameters:
	- scale: 2
	- step: 3
[20:50:13.482341][info] PlaneSweepingCuda:
	- _nImgsInGPUAtTime: 2
	- scales: 2
	- subPixel: Yes
	- varianceWSH: 4
