David scanned by David - work in progress
Curiousjeff
Re: David scanned by David - work in progress
Post by Curiousjeff » 08 Sep 2017, 10:14
Your settings are nearly identical to mine, except that I use YUY2 & Disabled (adjusted within David).
All other settings are adjusted using FlyCapture before.
1) The "Quality check & Outlier removal must be adjusted to your setup (scale size, power of projector, etc...). Start low and increase until you have enough good information to build a full model by overlapping scans without holes.
2) in Flycapture, (while David is projecting a pattern !) , zoom with the mouse and fine tune fps and shutter until most stable image using absolute values. First FPS, then shutter
My procedure is for a global shutter/ mono camera !!!
3) What is your f-stop setting ?
4) Don't use gain if possible.
5) Practice on neutral item to start (simple item painted light mate grey).
Good luck
Curiousjeff
Post by Curiousjeff » 08 Sep 2017, 10:20
Your bad alignment is a problem. I can't help much.
The problem is:
Camera lens
AND/OR
Projector settings
AND/OR
Projector lens
AND/OR
Precision of calibration panel
AND/OR
Angle between camera and projector if out of usual range
3dscanner
Post by 3dscanner » 11 Sep 2017, 15:15
my f-stop is 1:1/4
my camera is color
if i set up as you,i will see many black dot on the screen
now the alignment is better
Post by 3dxcan » 12 Sep 2017, 02:16
3dscanner wrote:
11 Sep 2017, 15:15
my f-stop is 1:1/4
my camera is color
Set all Your white balance values for Red,green, blue to a single value. Your problem with Sine wave fluctuations and dotted picture will be solved.
3dscanner
Post by 3dscanner » 14 Sep 2017, 03:29
thank Curiousjeff and 3dxcan for your help!
Who is online
Users browsing this forum: No registered users and 2 guests
