Your settings are nearly identical to mine, except that I use YUY2 & Disabled (adjusted within David).
All other settings are adjusted using FlyCapture before.
1) The "Quality check & Outlier removal must be adjusted to your setup (scale size, power of projector, etc...). Start low and increase until you have enough good information to build a full model by overlapping scans without holes.
2) in Flycapture, (while David is projecting a pattern !) , zoom with the mouse and fine tune fps and shutter until most stable image using absolute values. First FPS, then shutter
My procedure is for a global shutter/ mono camera !!!
3) What is your f-stop setting ?
4) Don't use gain if possible.
5) Practice on neutral item to start (simple item painted light mate grey).
Good luck
David scanned by David - work in progress
Re: David scanned by David - work in progress
Your bad alignment is a problem. I can't help much.
The problem is:
Camera lens
AND/OR
Projector settings
AND/OR
Projector lens
AND/OR
Precision of calibration panel
AND/OR
Angle between camera and projector if out of usual range
The problem is:
Camera lens
AND/OR
Projector settings
AND/OR
Projector lens
AND/OR
AND/OR
my f-stop is 1:1/4
my camera is color
if i set up as you,i will see many black dot on the screen now the alignment is better
my camera is color
Set all Your white balance values for Red,green, blue to a single value. Your problem with Sine wave fluctuations and dotted picture will be solved.
thank Curiousjeff and 3dxcan for your help!
