120mm panel
0,16-0,17 rms
accuracy: 0,03mm
turn table and david sls3 dual camera
hp 3d scan 5.5.1
A few scans
Re: A few scans
Very Nice!!
Were those done with the use of the HP turntable?
Re: A few scans
Yes Alonso I use Hp turn table when scanning small pieces.
This is my scanner
Re: A few scans
Part size 33mm
I used a 60mm calibration panel.
Rms: 0.192 - 0.194
Accuracy: 0.01 mm
And very important, i used play dough to help align.
Rms: 0.192 - 0.194
Accuracy: 0.01 mm
Re: A few scans
@erol
Really very nice!
But how do you use the turntable with dual cameras?
Based on my knowledge it's not possible to use turntable with dual cameras.
Would be great if you have solution for his. Thanks
Really very nice!
Re: A few scans
Why do you say this? He appears to be using the David turntable which is sold with the 2 camera SLS system.
Re: A few scans
Only extended view is disabled when using turntable.
Re: A few scans
Hello there.
I'm using david sls3 with two cameras. The software is also HP 5.5.1
The turntable is the david turn table.
The system scans in automatic stereo mode when scanning with dual camera and automatic turntable. If you are going to use a manual turntable or a single scan, you can select an extended mode.
I didn't have any problems with double camera and automatic turn table scans.
