µ Scan O The Day
µ Scan O The Day
I spent the day yesterday scanning some vintage British motorcycle (Norton) parts for a friend.
erapip
Re: µ Scan O The Day
Post by erapip »
Micr0 wrote: 24 Feb 2018, 16:45 I spent the day yesterday scanning some vintage British motorcycle (Norton) parts for a friend.
Perfect....... ;)
What hardware you use? Version 5?
erapip wrote: 24 Feb 2018, 19:22
Perfect....... ;)
Yes. v5.3
2)IS DMK 23UX174 cameras
LG PF1500.
Post by bigbomber »
Nice scan. Did you use Global Registration?
bigbomber wrote: 25 Feb 2018, 11:52 Nice scan. Did you use Global Registration?
Global fine? Yes.
Hi Micro!
I saw your cameras are 1920x1200 global.
Which kind of lens do you use for the 1/1.2 sensor?
I have the std 23UX236 with 12 mm lens.
As stated by many people here it's too tele, but I did not try anything else for using with my std K132. Maybe 8-10 mm is good.
I just put my camera a few cm behind the projector, as David-HP does in its rig.
I guess they modify a little bit the throw ratio of K132+.
Ntw, Sony imx236 is 9 mm wide, while imx174LL is 21 mm wide.
k132 has a throw ratio of 1,49
LG PF1500 a throw ratio of 1,40-1,54
(so they are similar)
Do you use something wider than the equivalent: 12*21/9= 28 mm? (approximately)
