Handrest for a Swedish fighter jet:
Quite easy job. As usual 2x DMK 23UX236 with Computar 12mm and Optoma 750e.
RMS of 0,11 and 0,08. Calibration panels HP at 120mm. DIY Rotary table.
Mostly stereo mode except for the cavity (extended mode).
Handrest
Re: Handrest
Wow!
A very nice work Martan!
Still I can't realise why my 120mm panels performs so differently.
Are rms independent from the projector?
Re: Handrest
@mading,
I can check my settings again and send to you.
A faint memory about "panel angle compensation setting" affecting the RMS error quite heavily.
Re: Handrest
Thanks martan. You are very kind.
I'll take a picture of the panel and share it in another post. I thinks it's poorly printed.
Re: Handrest
v 5.2
Don't think I changed anything else.
Re: Handrest
The "joystick top" that sits in front of the handrest. Mesh and solid.
Re: Handrest
Hello martan,
Very good scan? Have you 3D Print the first Handrest? If you van share the STL i would like to 3D print it and see the top details how it will look.
Nice job!
Regards
