Some of my scans
Re: Some of my scans
OBNRacerMan wrote: 05 Nov 2020, 19:03
OBNRacerMan wrote: 05 Nov 2020, 18:44 In the program itself (during calibration) there are recommendations for installing the lens with the desired focal length for a given scanning area.
For the smallest 3rd zone, 16mm lenses are best. For the 4th zone (it is not included in the kit, but you can print the actual one), 25mm lenses are recommended. And 12mm is probably for the 1st and 2nd zones (large and medium) - I have never used them yet.
The size of my zone number 3 is 94.463mm, the size of my homemade printed zone number 4 is 58.744mm
Here, if anyone is interested, a link to several small fields for self-production (in CorelDraw v.13 format)
I also tried scanning with binning BIN4 - the resolution of the cameras is reduced by 4 times, but recalibration for this mode (in contrast to the software crop) is not required.
Scans:
The surface on the full resolution scan of the drill bit seems exceptional rough. Why do you suppose that is?
I think there are two main reasons: the drill has a black coating, it also has particles from its work.
If it were matted with a lightening compound, the result would be a little better.
In general, I was asked to scan the drill in order to evaluate how the use of binning would round off sharp edges.
Now, for the sake of interest, I rescanned the old object (which I had already laid out) - the frame of the gearshift lever - but with a new system.
1
1
2
2
3
3
Conducted a small test comparison of two scanning programs - HP3DScan and Rangevision DIY.
The test object was the lid of a coffee can - black, mostly glossy, but with some matte elements.
The same equipment was used - Daheng MER630U3-L cameras with 16mm ZLKC lenses and a time-tested Byintek projector with a resolution of 1280 * 720px
First, the old HP3DScan went into battle. He had a software limitation - he can only use one Daheng camera.
The shutter speed had to be set to 1/8 "(and for the camera (it has access to brightness and contrast correction in this program) the maximum brightness and minimum contrast were set.
This is what the object looked like in the HP frame:
And this is how a single scan element looked like in HP:
A total of 8 scans were made, after which the model was combined by means of this program and exported to STL.
After that, the RV DIY program worked from the same position.
It has no camera settings other than exposure. Therefore, the first shutter speed was set to 33 (1/30 ") and the second shutter speed to 133 (1/8") in order to avoid overexposure from glare that these cameras are exposed to in this program.
This is how the object looked in the RV frame:
And this is how a single scan element turned out in it:
Here I also made 8 scans, and then added the STL obtained at HP for comparison:
Compare scans - 1
Compare scans - 1
Compare scans - 2
Compare scans - 2
Compare scans - 3
Compare scans - 3
Left - RV, right - HP
In my opinion, the result was quite good in both cases. But RV better conveyed both the angles between the elements (between the "sun rays" and the base) and the very shape of the rays.
OBNRacerMan wrote: 30 Nov 2020, 22:08 Conducted a small test comparison of two scanning programs - HP3DScan and Rangevision DIY.
It looks like the RV error rejection/correction is more refined.
Black and reflective is tough for any SL type scanner. I have never had good luck scanning them with David and almost always spray the surface for that reason.
Micr0 wrote: 30 Nov 2020, 22:58 Black and reflective is tough for any SL type scanner. I have never had good luck scanning them with David and almost always spray the surface for that reason.
My previous Mindvision cameras were the best solution for HP3DScan - thanks to the huge number of settings, they scanned dark and black objects quite easily. Not to mention, these cameras can work together at HP. And if I had not switched to another software, I would have continued to enjoy life with them :D
OBNRacerMan wrote: 30 Nov 2020, 23:08
What settings did you change to get those cameras to scan dark items effectively? I can tweak some setting in the IS cameras, but I haven't really experimented with trying to make them work. I just sprayed the subject, which I'd like to not have to do with some things.
Micr0 wrote: 01 Dec 2020, 00:18 What settings did you change to get those cameras to scan dark items effectively? I can tweak some setting in the IS cameras, but I haven't really experimented with trying to make them work. I just sprayed the subject, which I'd like to not have to do with some things.
It all depends on the available parameters in the settings.
For the Mindvision SUA630 cameras, I used a decrease in the gamma value. Their shutter speed was always 1/60 ", the rest was controlled by the gain that works perfectly in them.
The gamma value decreased from 1.0 (default) to 0.75, sometimes 0.5 and even to 0.35:
Mindvision SUA630 parameters
The basic settings of Daheng MER630 cameras through their original control program are very poor, there is nothing but setting the shutter speed (you can also adjust the gain within small limits (but from HP3DScan this parameter cannot be smoothly adjusted - it is either off or maximum)). But in HP3Dscan for these cameras, brightness and contrast settings are available (unfortunately, the gamma parameter is inactive, and even if you trick it and enable it, it still does not work in HP). I scanned with these settings:
Daheng MER630 parameters
P.S. In the RV software for cameras there are no settings other than exposure and resolution switching between full and BIN4
mr_cg
Post by mr_cg »
The Rangevision DIY looks very interesting. Is it possible to use the HP S3 Kameras, Acer K132 projector and HP rail setup with Rangevision DIY software?
In this case i would like to try Rangevision software.
mr_cg wrote: 04 Jan 2021, 20:51 The Rangevision DIY looks very interesting. Is it possible to use the HP S3 Kameras, Acer K132 projector and HP rail setup with Rangevision DIY software?
The projector can be anything, the mounting system of the whole structure can also be any ... but cameras (for DIY version) should only be either UCMOS3100KPA (USB2.0 3.1Mp, 1/2", 8fps) or Daheng Mercury MER-630- 60U3M-L (USB3.0, 6.3Mp, 1/1.8", 60fps, monochrome). I have the last of this short list. And there must be two cameras (the option with one camera is not supported).
P.S. IDS cameras are also supported.
