A Few Hardware Scans
Post by Micr0 » 31 May 2018, 18:57
I found some old hardware in an Antiques store a couple weeks back. Here are some of the scans:
A Cast Iron Cabinet pull Calibrated at 120mm. The pull is ~80mm tall.
More Later
erapip
Re: A Few Hardware Scans
Post by erapip » 02 Jun 2018, 22:14
As always Micr0 beautiful scans :P
What is the purpouse of it?
Im sharing one of my last scan. Hope you like it.
Regards
Post by Micr0 » 06 Jun 2018, 11:02
erapip wrote:
02 Jun 2018, 22:14
Regards
Great clarity! Very nice detail. Just curious, have you checked your dimensional accuracy? Are you parts measuring in David what they are in the "real" world?
These scans(I will post a few more), are of cabinet hardware. The handles one uses to open cabinet doors.
illbefucd2
Post by illbefucd2 » 08 Jun 2018, 08:25
Hi to All,
this is probably a very dumb question as im only very new here
But how do we measure in david the accuracy or how do we measure the scan.
Thanks in advance
Post by Micr0 » 08 Jun 2018, 11:25
illbefucd2 wrote:
08 Jun 2018, 08:25
Hi to All,
Thanks in advance
I'm assuming you are using version 5 of David In that there is a measure feature with which you can click on 2 points and David will give you the distance between them. You can then compare that to measurements you do on the scan subject in the physical world. Say measuring between two machined faces on a casting with a caliper or micrometer etc.
illbefucd2
Post by illbefucd2 » 16 Jul 2018, 13:33
Thanks for the reply. I have David 5 and ill try. But I have other issues I think I need to sort out this calibration.
