Scaling Issue
kate_Jelaine
Scaling Issue
Post by kate_Jelaine »
I am using FlexScan3D software and it appears that each of my separate meshes have different scales. Is there a way to ensure that all of the created meshes have the same scale?
Thanks
Re: Scaling Issue
If during the scanning process for some scans the sharpness settings of the cameras or the projector were changed (even changing the aperture of the cameras can play a negative role), then it is quite possible to change the scale.
If I'm not mistaken, FlexScan3D, like David / HP3DScan, uses joint calibration of both the camera and the projector, in contrast to the ScanCenter from RangeVision (where only cameras are calibrated).
