Page 1 of 2
Control Stick
Posted: 12 Jul 2018, 17:15
by martan
Control Stick for a fighter aircraft. Which one?
Sprayed with cyclododecane. Surface not perfect but the need for no cleaning of spray after makes it ok anyway.
Number of scans is more than I wished for.
Stereo mode, Manual turntable (I think I like this best. "IKEA Snudda" sprayed with matte black.)
RMS of 0,08 & 0, 07, Original HP-panels 120mm scale. It aligns very well!
Re: Control Stick
Posted: 12 Jul 2018, 19:13
Awesome!
Re: Control Stick
Posted: 16 Jul 2018, 02:29
by nancyluo
Done by Thunk3D colorful Desktop 3D Scanner Cooper C20 with Accuracy about 0.08mm
Re: Control Stick
Posted: 18 Jul 2018, 13:48
martan wrote: ↑12 Jul 2018, 17:15
Excellent! Thanks for sharing.
Re: Control Stick
Posted: 07 Aug 2018, 08:01
by martan
More experimenting:
20 scans on automated turntable.
- Before alignment
Mobile-clip of the alignment.
https://www.youtube.com/watch?v=yw-N7-t6srg
(Intel i7 6700k 16GB RAM)
- Aligned but not fused
Re: Control Stick
Posted: 07 Aug 2018, 21:14
Great job Martan.
I have the david panels, and I got 0.14 on the 240 mm panel, but higher (0.23-0.40) on the 120.
Sme cameras and lenses.
Different projector (acer k132 non hp)
Do you use inside corner?
Re: Control Stick
Posted: 08 Aug 2018, 11:11
by martan
Mading,
I use 120mm scale "inside corner". I turn the panels until cameras "see the same" - until RMS is equal.
This case 0,07-0,08-ish on both. I tried the setting "Compensate angle between panels" It doesn't seem to affect
RMS much but the scans aligned horribly.
Projector and cameras. Not even the same distance from projection lens.
Sorry about the messy "cave"
- Man Cave
Again 20 scans:
- 20 scans
Re: Control Stick
Posted: 08 Oct 2018, 19:01
by martan
Another control stick for a fighter aircraft. Stick itself scanned in stereo mode and the base is
scanned mostly in extended mode. Optoma ML750e, 2x TIS 23UX236 with 12mm
Computar and original HP Calibration panels 120 mm. Works fine without to much problems.
Greetings from Sweden
- Control Stick
Re: Control Stick
Posted: 09 Oct 2018, 12:37
Always great job Martan!
Nice to see you are active.
Re: Control Stick
Posted: 09 Oct 2018, 15:27
martan wrote: ↑08 Oct 2018, 19:01
Nice work! Thanks for sharing.
