Gear Case
Re: Gear Case
Great work micro!
Re: Gear Case
It turned out great, considering that it was done in HP3Dscan, where there is no way to combine separate parts of the scans by labels.
Re: Gear Case
Am I to assume that in RV you can do this?OBNRacerMan wrote: ↑08 Dec 2020, 17:07 It turned out great, considering that it was done in HP3Dscan, where there is no way to combine separate parts of the scans by labels.
Re: Gear Case
Yes, marker support was one of the reasons why I switched to this software (of course, easier calibration with flat panels and the presence of an automatic turntable are also important.
P.S. And now the table can be made by yourself - they (RV) recently laid out for us the necessary information about the DIY firmware of the table to work with their program.
Re: Gear Case
That is awesome that they allow you to use your DIY turntable
Re: Gear Case
Does RV have a remote trigger option?OBNRacerMan wrote: ↑08 Dec 2020, 20:40Yes, marker support was one of the reasons why I switched to this software (of course, easier calibration with flat panels and the presence of an automatic turntable are also important.
Re: Gear Case
I don't quite understand what is meant by "remote trigger" in this case.
If you mean starting scanning, then you can start typing by pressing the button on the screen, or the "space" key on the keyboard.
If we are talking about using additional connectors for external synchronization available on some cameras, then most likely this is not the case.
P.S. Or an option like HP3DScan - when the program looks at changes in the frame, and while they are there, it waits, and as soon as it notices their absence, it starts scanning itself - I have not seen this here.
Re: Gear Case
.OBNRacerMan wrote: ↑09 Dec 2020, 17:38I don't quite understand what is meant by "remote trigger" in this case.
I meant being able to listen to a comm port and trigger off an received character.
Re: Gear Case
No, I have not heard about such a function yet. But if there are many who want to get it, then RV will implement it - here I like that there is feedback and they listen to the opinions of users (of course, not everything can be implemented, but something appears sooner or later, making the software even more convenient)
