Gear Case
Re: Gear Case
Micr0 wrote: 09 Dec 2020, 20:23 I meant being able to listen to a comm port and trigger off an received character.
The arduino sketch for the RV turntable works with serial input output command from/to the arduino controller.
Do you need that trigger for other purposes than the turntable?
For istance for a series of manual scan triggering from a remote control?
An arduino remote trigger connected by bluetooth / wifi?
Re: Gear Case
Post by bigbomber »
OBNRacerMan wrote: 08 Dec 2020, 20:40
Micr0 wrote: 08 Dec 2020, 18:35 Am I to assume that in RV you can do this?
8-)
Yes, marker support was one of the reasons why I switched to this software (of course, easier calibration with flat panels and the presence of an automatic turntable are also important.
P.S. And now the table can be made by yourself - they (RV) recently laid out for us the necessary information about the DIY firmware of the table to work with their program.
Hi
I need RV software to try on it. can you help?
Re: Gear Case
bigbomber wrote: 10 Dec 2020, 18:50 Hi
Hi. I answered in a personal so as not to litter here in the personal section of Micr0
erol
Re: Gear Case
Post by erol »
Nice work micro
Raptorex
Re: Gear Case
Post by Raptorex »
Looks awesome
