Do you need more...
Do you need more...
Post by martan » 13 Jul 2018, 17:38
... resolution?
This cable lead through is about 10 cm. Sprayed with this:
https://www.3djake.uk/fabconstruct/3d-s ... ting-spray
Fusion
Scans
Re: Do you need more...
Post by nancyluo » 16 Jul 2018, 02:26
How do you feel about these images?
More details and high accuracy
Done by Thunk3D handheld Scanner under "fine mode" with dot pitch 0.12mm
