Turbine housing scanned with FlexScan3D
After spending all last week getting acquainted with FlexScan3D and constantly tweaking my hardware, I feel this is worthy of sharing
Re: Turbine housing scanned with FlexScan3D
Very nice indeed!
Good job!
You're proud of this??...
Just kidding of course, nice work! - Learning quick!
Thanks everyone!
With HP3dscan I DID NOT look forward to fusing the scans together. There was nothing worse than getting to the end only to find out your scans don't quite fit together 100%. Not to mention how time consuming the process was.
With FlexScan3D, I now look forward to finalizing my scans. After learning the keyboard shortcuts and the workflow when working with meshes, the process is actually enjoyable and productive.
Good job Polyga!
Ha! Thanks!contactpolyga wrote: ↑08 Feb 2021, 22:10 You're proud of this??...![]()
Good job Polyga!
Great job Alonso!
HiAlonso wrote: ↑09 Feb 2021, 01:18 Thanks everyone!
Ha! Thanks!
Good job Polyga!![]()
Can I know about your Hardware: PC, Cameras, Projector and calibration Panel
Custom pc based on 9600k processor, 1080p dlp projector, 3mp cameras with global shutter.
As for the calibration panel, it's just a 15mm calibration pattern that I printed at work then taped onto a piece of glass
Eventually I'll get a proper calibration panel from Polyga
Hi Alonso. Thanks for sharing.
I would be interested in which kind of cameras. IS?
