accuracy problem
erol
accuracy problem
Post by erol » 27 Aug 2018, 21:15
Hello friends.
Scans have dimensional accuracy problems (0.2mm-0.4mm).
Part length 55mm
My setup
calibration panel: 60mm (original hp panel)
dual cameras (david sls3)
hp 5.5.0
turntable
calibration values,
camera1 angle: 17.93 ˚ ===> Rms: 0.115
camera2 angle: 17.85 ˚ ===> Rms: 0.178
total: 36 scans
Why the dimensional accuracy is bad and what should I do to fix it.
Re: accuracy problem
Post by Micr0 » 27 Aug 2018, 23:34
How are you deriving those error numbers/ How are you measuring the accuracy?
Also what is the scan subject? what is it made of?
erol
Post by erol » 28 Aug 2018, 21:49
Thank you Micro for your fast replay.
I made measurements again with my digital calipers tonight and yesterday I was wrong. The part material is silicone. When measuring, the part caused the wrong measurement because it stretched.
I froze the piece deep freeze before the measurement this evening (5 hours).
as a result the accuracy is 0.02mm :)
Post by Micr0 » 28 Aug 2018, 22:08
erol wrote:
28 Aug 2018, 21:49
Squishy (very technical term) parts are difficult to get accurate measurements from. I had suspected thus. Glad you solved you problem. :D
Post by mading » 29 Aug 2018, 07:07
Dear Eol,
Do you use the david Acer K132+?
Post by martan » 29 Aug 2018, 08:17
Nice scan!
erol
Post by erol » 29 Aug 2018, 19:31
Thank you.
I have a david sls3 scanner (dual camera and v5.5) and original acer k132 +.
Another scan but I did not check accuracy :D
Post by Micr0 » 30 Aug 2018, 14:21
Very nice. You seem to be getting excellent results. Are the surfaces of your scan matching in smoothness to that of your subject?
erol
Post by erol » 30 Aug 2018, 15:17
Thank you Micr0,
The surface smoothness in the scans is generally good and matches the object.
