Some of you may remember the offer that Polyga put out for the custom 3d scanning projector a while back...well, I got one!
This is a point cloud done on the scanner in handheld mode. It's not perfect but I still wanted to share!
Still need to make some changes but the results are looking promising!
Alonso wrote: ↑07 Jul 2021, 05:05
You did it! Thanks for sharing! Did you use the IS cameras or moved to faster basler?
The hardware is compatible with Basler cameras only. Handheld scanning requires some seriously fast fps cameras too which really narrows down the choices...
And due to shortages and the state things are in right now, I was extremely lucky to have been able to find a pair of cameras(although I had to buy each camera from 2 different suppliers!).
Most suppliers had a lead time of 10 weeks for a single camera!
Alonso wrote: ↑07 Jul 2021, 11:11
Mading,
Thanks Alonso
Would you mind to share the model you found?
Mading,
Thanks Alonso
I'm running a pair of Basler acA640-750um cameras.
The other choice was acA720-520um but this one I couldn't a pair available to buy off the shelf. Only one supplier had a single camera in stock here in the US. Everybody else had a lead time of a minimum of 10 weeks. I didn't really want to wait that long to try out the scanner
And an update on this cool pot
Re-scanned after the following changes-
Repositioned the cameras
Focus adjustment
Aperture adjustment
Recalibration
Better PC hardware currently on loan to me
The new pc allowed the scanner to run at the Auto fps setting which gives a nicer scanning experience overall.
The following scan was done in a single capture. No stitching meshes together whatsoever.
Slight smoothing and decimated the mesh to 30%
The pot stands about 277mm tall
