New scans with FlexScan3d
Re: New scans with FlexScan3d
erol wrote: 24 Sep 2022, 17:52 Thank you Micr0.
I bought the cameras a few months ago. The lenses I use
Zlkc 12mm and Huateng (same as zlkc) 25mm lens. Projector Lg pf1500. I'm selling my david sls3 scanner completely.
AliXepress is saying those cameras are no longer available.
Did you have any problem with Flex recognizing the Mindvision cameras? Looking at similar imaging source and they are almost $1k
Micr0 wrote: 25 Sep 2022, 00:53
The modified version of FlexScan can support Mindvision and Daheng cameras perfectly.
but I recommend Daheng cameras. it has built-in Binning option which is very useful.
by using Binning option, you have two cameras in the same package: one 6.3MP camera and one 1.57MP camera.
all of these cameras are based on the IMX178 sensor.
so the other options are only related to camera firmware and manufacturer quality.
✅ ImagingSource DMK 33UX178
✅ Daheng MER2-630-60U3M
✅ MindVision SUA630M
✅ Basler acA3088-57um
greenskynet wrote: 25 Sep 2022, 08:39 but I recommend Daheng cameras. it has built-in Binning option which is very useful.
Hi. And where does hardware binning come from on Daheng? (I saw only software binning on them, the inclusion of which loads the system very heavily) But Mindvision, BIN2x2 is directly in the drivers. But there are problems there too.
OBNRacerMan wrote: 25 Sep 2022, 09:17
any Daheng cameras shipped after July 2022 support binning. The elder versions don't have this great option.
by using built-in Binning option, there isn't any extra load on PC and CPU. Also you can achieve so much higher fps and stable frame-rate
Also some members of my group have MindVision cameras and we tested BIN2x2 option on them. it doesn't have correct behavior via both SDK and DirectShow on any software, including HP and FlexScan.
mr_cg
Post by mr_cg »
Flexscan3d looks quite interesting. I have 2x Daheng cameras and Acer K132 projector and would like to test Flexscan.
Is there any trial licence available to check how my setup is working?
mr_cg wrote: 25 Sep 2022, 10:19 Flexscan3d looks quite interesting. I have 2x Daheng cameras and Acer K132 projector and would like to test Flexscan.
contact me via Telegram: https://t.me/DIY_3D_Scanner
erol
Post by erol »
Buying from this store on aliexpress
https://www.aliexpress.com/item/3281763 ... pt=glo2tur
I could not buy the cameras directly due to the limit for Turkey. I made an agreement with the seller Price of 2 cameras = price of 10pcs 12mm lenses, I bought 10pcs lenses, seller sent me 2 pcs of sua630 (cables included) :D .
I am using flexscan modified version and it works very well with flex.
As greenskynet said, daheng cameras are a bit better, I thought to buy daheng mer2 630 but it was too expensive for my country :| .
