My Scan Projects Modified version of FS
Hi everyone
Here I post some of my scan and reverse engineering results 😍😎
this is a centrifugal Pump:
All parts are scanned, reverse engineered and assembled.
Scanner: DIY scanner, HD projector, 6.3MP cameras
Scanning software: Modified version of FlexScan3D
Reverse Engineering Software: CATIA V5
https://t.me/DIY_3D_Scanner
Khalid
Re: My Scan Projects Modified version of FS
Post by Khalid »
Incredible details
new pump Scan
Is it me or are you scans getting better? Seems like the detail is sharper.
Micr0 wrote: 11 Dec 2023, 18:07 Is it me or are you scans getting better? Seems like the detail is sharper.
Ah, Yes😅
I added some new functions to the software to enhance the scan and surface quality, so after finalization, the edges remain sharper.
meanwhile I upgraded my scanner projector from a 800x600 old one to a new projector with HD resolution.
3D scan and Reverse Engineering
This is one of my old scans, I posted for comparison with my newer scans.
new Glob valve scan 😎
What happens if you scan something like that with out markers? Is there a noticeable difference in alignment of accuracy?
Micr0 wrote: 17 Dec 2023, 15:29 What happens if you scan something like that with out markers? Is there a noticeable difference in alignment of accuracy?
about accuracy, markers doesn't have any effect on final accuracy. but the scan process with be so much difficult and time consuming without markers.
