i purchased balls with a known sphere diameter of 20mm measured with micrometer. The scan results shows the ๐ฑ๐ฒ๐๐ถ๐ฎ๐๐ถ๐ผ๐ป ๐ฏ๐ฒ๐๐๐ฒ๐ฒ๐ป ๐๐ฝ๐ต๐ฒ๐ฟ๐ฒ๐ ๐ฌ.๐ฌ๐ฌ๐ฎ๐บ๐บ ๐ฎ๐ป๐ฑ ๐ฌ.๐ฌ๐ฌ๐ด๐บ๐บ ( seems the thickness of white spray coating). The actual ๐ฐ๐ฒ๐ป๐๐ฟ๐ฒ-๐ฐ๐ฒ๐ป๐๐ฒ๐ฟ ๐ฑ๐ถ๐๐๐ฎ๐ป๐ฐ๐ฒ between two balls are 100.075mm and the scan measurement shows 100.086mm (๐๐๐ฎ๐ป๐ฑ๐ฎ๐ฟ๐ฑ ๐ฑ๐ฒ๐๐ถ๐ฎ๐๐ถ๐ผ๐ป ๐ถ๐ ๐ฌ.๐ฌ๐ญ๐ญ๐บ๐บ).
๐ช๐ต๐ฎ๐ ๐ฎ๐ฟ๐ฒ ๐๐ผ๐๐ฟ ๐๐ต๐ผ๐๐ด๐ต๐ ๐ฎ๐ฏ๐ผ๐๐ ๐๐ต๐ฒ ๐ต๐ผ๐บ๐ฒ ๐ฏ๐๐ถ๐น๐ ๐๐ฐ๐ฎ๐ป๐ป๐ฒ๐ฟ ๐ฎ๐ฐ๐ฐ๐๐ฟ๐ฎ๐ฐ๐ ๐๐ฒ๐๐?
I am using modified Flexscan3D software by greenskynet.
Khalid wrote: โ04 Jan 2024, 12:12
I've done similar by scanning standards used to calibrate micrometers and have found similar if slightly larger deviations. I've also used a Zeiss CMM. to measure objects after I've scanned them and confirmed that, depending on the calibration, I could consistently expect about 0.01mm. However, I was not using flex scan. I was using David.
