Scanning van interior
SilverApe
Post by SilverApe » 17 Dec 2018, 09:59
Hi all,
I don't own a 3d scanner (yet). I have messed a bit with the kinect (5 years ago, and it was cool). I have read a lot and seen a lot of different scanners (on the internet).
I am a carpenter and I would like to scan the interior of a van for measurements. I design my work in sketchup or fusion 360. I would like to be able to import my scan in any of those packages and use it as a reference.
I really don't know what scanner I should make/buy. Any advice would be welcome.
New to my options is Lidar. I saw some cheap Chinese Lidar devices. Is Lidar something that could be used for this?
It does not have to be super precise. Around 1mm would be sufficient. Easy/fast to setup. Not to expensive to buy/make.
Did I forget something?
Thanks in advance.
Aaron
Re: Scanning van interior
Post by Micr0 » 20 Dec 2018, 15:03
SilverApe wrote:
17 Dec 2018, 09:59
Hi all,
Thanks in advance.
Aaron
Whats your budget? There are some fairly good hand held scanners that are probably good for what you want to d in the $5k range.
SilverApe
Post by SilverApe » 23 Dec 2018, 19:14
Hi Micr0,
That is to expensive for me. I think my budget will be around €1000 but I will see what comes up as a good scanner and maybe I have to save some money to buy a good one.
I would just like to know now what would be a good method/scanner to scan an interior of a van. This way I know where or what to search for.
greetings,
Aaron
