3D Path Tracking
3D Path Tracking
I'm looking for a pretty environment-flexible, intuitive 3D motion tracking solution. I need to track a single point/tracer around a path in 3D space, and capture that path rendered in 3D space. Any pointers to technologies to explore would be very appreciated.
Re: 3D Path Tracking
Not low cost, but this does exactly what you need.
https://optitrack.com/
If you want something cheap, look at the Intel tracking RealSense solution, or use a HTC Vive Tracker, - both of the above solutions are a few hundred dollars. Not "cheap" but since industrial tracking is in thousands of dollars range.. it's pretty cheap.
