xyz 3d scanner, can it work with an non-intel cpu?
monjanse
Post by monjanse »
can pc without intel cpu use xyz 3d scanner, even when the sellers says that it must work on intel? i just ordered a xyzprinters 3d scanner, happy and looked forward to scan 3d figures, but then after ordering i watched a tutorial that says it is only supported by intel, and i have just an amd ryzen 7 8core cpu...
Re: xyz 3d scanner, can it work with an non-intel cpu?
monjanse wrote: 11 Oct 2017, 19:48 can pc without intel cpu use xyz 3d scanner, even when the sellers says that it must work on intel? i just ordered a xyzprinters 3d scanner, happy and looked forward to scan 3d figures, but then after ordering i watched a tutorial that says it is only supported by intel, and i have just an amd ryzen 7 8core cpu...
It is USB correct? I don't see why it wouldn't work with you machine providing you are running a supported OS.
monjanse
Post by monjanse »
i have usb 3.0.
