Leica BLK360 -->Bentley POD Format
Discussions about software for post-processing, usage of 3d scans and everything else you might do after you have scanned an object.
Jedimeister
Post by Jedimeister » 08 Apr 2019, 15:47
Hi folks!
I'm a new to the 3D Scan things, and hopefully you could suggest a proper working workflow for my current setup.
I've got a Leica BLK 360, I am stitching the files with Ipad Pro (Autodesk Recap Mobile Pro) and Autodesk Recap Pro.
Now I need to transfer these results to Bentley Pod, because it's the only format that is compatible with siemens NX reference point cloud solution.
From Autodesk i can export to this formats:
-E57
-PTS
-RCP
-RCS
and how could/should i transfer this to Bently .pod?
Thanks!
Jedimeister
Re: Leica BLK360 -->Bentley POD Format
Post by Jedimeister » 09 Apr 2019, 11:02
Hi folks!
I've found a solution: Point Tools from Bentley
https://www.bentley.com/de/products/pro ... -pointools
It's free of charge, but you have to register at bentley.
Br.
Post by Micr0 » 09 Apr 2019, 12:17
Interesting. Thanks for the link.
