I was unaware that in David, you could select multiple scans using shift and scrolling down the scan list.
Great for quickly selecting some scan to group.
Shift select some scan within the scan list
Re: Shift select some scan within the scan list
With the new feature in HP V. 5.1: "Align Sequence" (right-click menu on Shapefusion List of Scans), the multiple select if even more useful.
To work correctly, you can shift click (and hold shift) on the NAME of a scan and then drag your mouse up or down.
Then use "Align Sequence" on those selected scans.
Be careful not to do this on the check box itself.
