Scanner and Photogrammetry Band Together
Use this section to get into contact with manufacturers and vendors. Manufacturers can update you here about their latest tools. Posts in other subforums that have advertising character will be moved here or deleted.
Post by nancyluo »
Thunk3D Handheld Scanner integrated Photgrammetry together. It would be easy to keep the accuacy stable and higher for big object.
Blow is the Electron Motor Car Scanner by Handheld Scanner and Photogrammetry
Re: Scanner and Photogrammetry Band Together
nancyluo wrote: 06 Sep 2018, 03:13 Thunk3D Handheld Scanner integrated Photgrammetry together. It would be easy to keep the accuacy stable and higher for big object.
Please describe more of the technical aspects of this process. Include detail please. How does you software integrate photogammetry with the point cloud data generated from the SL process? How is this system calibrated and what is the advantages and disadvantages?
Post by nancyluo »
Hi Micro. There is "frame" mode in our software, and you only need to import such file of photogrammetry into our scanner and then start scan.
So easy. You can buy special photogrammetry pack from us or you just need to tell us the format of your photogrammetry file, our technicist would update our software to support your photogrammetry file. Details search Thunk3D in youtube.
