Use interchangeable lenses with Logitech Brio 4K webcam
Finally got time to rework Logitech Brio 4K webcam to be used with C/CS lenses: http://kurokesu.com/main/2017/07/31/mak ... ven-better
Re: Use interchangeable lenses with Logitech Brio 4K webcam
Hey SauliusL,
Amazing project you have there, thank you for sharing this info.
My Brio project is unrelated to 3D scanning, but probably you can help me, as you know the Brio hardware well
I want to use my Brio to create a time-lapse - fixed in one place for years, taking picture every few secs.
Problem is the infinite-focus of default Brio lens - it can't focus properly, distant objects are blurred.
Do you know if I can adjust the focus manually on the brio hardware, after dismantling it?
Another point: would you advise to use other lens, than the Brios' default one (like you did), for 90deg fixed-infinite-focus pictures? I.e. is there much better picture quality achievable then?
I'm impressed with your project, SauliusL. Have you done any work on it since then btw?
