Making 380mm Panels
Making 380mm Panels
Literally the largest I can plot on one sheet on the Graphtec.
Re: Making 380mm Panels
Post by 3dxcan »
that's interesting, however with larger calibration corner you have to get farther from the object and lose small details if any. How far do You plan to get from the calibration panel/ object?
Great!
I don't have such an equipment.
I found a shop on the nearby that print on almost everything, including wood panels, I made my 220 mm.
Around 20€ for both, only the print.
Cheers
