First happy new year 2020 for all of you.
I try to do the following workflow: export scan as obj--->import in G.Wrap and perform a global Aligment-->export as obj-->make the Fusion 1500, -2 back i DAVID and it was better than doing only from DAVID.
WHAT IS YOUR ECPERIENCE ON THESE WORKFLOW?
REGARDS
Gromagic Wrap
Re: Gromagic Wrap
Why do you say it is better than doing it completely in David? Is the alignment in Wrap faster or more accurate than David?erapip wrote: ↑02 Jan 2020, 14:15 First happy new year 2020 for all of you.
REGARDS
Re: Gromagic Wrap
I think he meant that alignment there is sometimes a little easier, because three points are done.
But my opinion is that if the scan is initially “crooked” - then in what program do not try to add it - nothing good will come of it.
Re: Gromagic Wrap
OBNRacerMan wrote: ↑03 Jan 2020, 14:16I think he meant that alignment there is sometimes a little easier, because three points are done.
After performin "Global Fine Aligment" still in Fusion it was visible some "mistakes" from bed scan coverage areas (i also try contact pair but doesent work). Than in G. Wrap i did only do the "Global Aligment" and re-export in DAVID. So in my experience it was much accurate that David. Thats why i asked if somebody else had these experience!
