Budget Scanner for Boat?
jwells
Post by jwells »
I would like to scan a 35ft boat into AutoCad.
What is the scanner that can do it?
Under 5k hopefully.
Re: Budget Scanner for Boat?
I would try to use photogrammetry for such a large task (but a program in which everything has to be processed later must be able to work with markers or control marks - this will ensure sufficient accuracy). Agisoft Metashape can do just that (I haven’t figured out yet whether 3DF Zephyr can do this)
P.S. And, in any case, after scanning in any way, only the “basis” will be obtained, on which it will be necessary to independently make all sections and structures.
And this is the easiest and cheapest way, quite suitable for "scanning" very large objects
OBNRacerMan wrote: 26 Mar 2020, 08:47 I would try to use photogrammetry for such a large task (but a program in which everything has to be processed later must be able to work with markers or control marks - this will ensure sufficient accuracy). Agisoft Metashape can do just that (I haven’t figured out yet whether 3DF Zephyr can do this)
What he said ^^^
This is a perfect candidate for free photogrammetry apps. There are a bunch out there. Once you have a scan you will convert it to a mesh and need to learn one of the free mesh editing apps (meshmixer, Mesh lab). For there into CAD etc....
There a bunch of people on reddit (r/3DScanning) doing this exact sort of thing.
