I would like to scan coils of wire, similar to the attached photo. The diameter of these coil wings are approximately 10cm so the whole object is 20cm end to end. The cable in this case is black but ot can be coated. The wire layers sometimes overaap so scanning from all directions will be required. Would the Einscan 2X Pro be suitable for this? Any recommendations?
thanks a lot
Gaby
