360° alignment issue and calibration settings questions
Re: 360° alignment issue and calibration settings questions
mr_cg wrote: 05 May 2020, 20:23 Thanks Micro0 for the information. How did you mill the bigger circles with white dot in the middle? Based on the official HP printouts the black dot is /30 from the scale. Is the size of the point important or just only the position?
AFAIK Just the position. That is the toroid I milled with the smaller endmill. It was a profiling toolpath. The original David calibration PDF files had that circle a just twice the diameter of the black dot. The white center was the same diameter as the other black dots. the new calibration panels seem to have bigger donuts, but I have only seen pictures, and I don't know why they may have done that. Perhaps it helps David with the calibration?
