I'm having issue with this do3think camera i just purchased... I can see it on HP scan but it shows blank. is it in the wrong address and how do i correct it? It's been awhile since i posted and trying to get back into things after a hiatus. Have usbview but i have no idea how to use it
Do3think camera
Re: Do3think camera
What is written in the Hp3DScan log window? This program uses DirectShow to operate cameras.
Re: Do3think camera
it's pretty shoddy, only the supplied Chinese software can see it so i have no idea how it works. HP sees it but it shows blank and camera settings is locked out
https://www.ebay.ca/itm/273485841250?Vi ... 3485841250
Re: Do3think camera
As far as I understand, this is a very old camera (perhaps it is worth trying the drivers (M3S_USB3.0 工业 相机 _V2.50.65.683) from its more modern counterpart - M3ST130M-H)?
Re: Do3think camera
HiOteck wrote: ↑02 Feb 2021, 06:52 I'm having issue with this do3think camera i just purchased... I can see it on HP scan but it shows blank. is it in the wrong address and how do i correct it? It's been awhile since i posted and trying to get back into things after a hiatus. Have usbview but i have no idea how to use it
Can I ask from where do you have access to the second window? (the window you captured a screenshot in the second photo)? Is it from Device Manager?
Re: Do3think camera
thats from USBView OBNracerMan posted in the forum
Re: Do3think camera
Still, what does the HP3DScan program write in the service console?
This must be enabled in the HP settings.
There are errors in this screenshot because I don't have a scanner on this computer.
