Page 7 of 11
Re: Projectors... and Projector Mods.
Posted: 01 Feb 2018, 15:45
by erapip
bigbomber wrote: ↑31 Jan 2018, 20:56
Hi
Friends, can you tell me how much is RMS Error value for you after calibration?
in setting/service ==> check "Show Debug Console".
see following photo how to find it.
What does it mean? How should it be?
Mine was 1.1
Posted: 01 Feb 2018, 16:51
by bigbomber
Mine was 1.1
1.1 is a big value of error. Are you sure?
As I know in a perfect calibration process it must be near to zero.
It is interesting for me how you can get good result by your scanner.
Can you double check the RMS Error and check alignment quality?
Posted: 01 Feb 2018, 19:14
by erapip
[Qquote=bigbomber post_id=1090 time=1517503901 user_id=164]
Mine was 1.1
[/quote]
Yes if i find time tomorrow
Thnx
Posted: 02 Feb 2018, 10:54
by erapip
Sorry my mistake it was 0.11
I try to optimize the setup and arrive to 0.08
What do you think that afect these values?
Thanks
Posted: 02 Feb 2018, 17:13
by bigbomber
erapip wrote: ↑02 Feb 2018, 10:54
Thanks
RMS Error shows how well your calib panel is made or how well your camera can read your calib panel.
0.1 is a good value.
Can i know if you get this value with Nikon or using Industrial camera?
As i remember you have IDS cams. Why do you do your scans using Nikon?
Posted: 02 Feb 2018, 19:42
by erapip
bigbomber wrote: ↑02 Feb 2018, 17:13
Thanks
Yes it is with NIKON. IDS is veri slow on datta capture. With Nikon it goes to 1080p if i remember right. If is necesary i can try with IDS just to compare. I think my projector is not OK for scanning. Can you suggest one model?
Why do you use version 4 of David and not 5?
Posted: 02 Feb 2018, 20:10
by lovebay1
I think this is very good...I'm surpised
Posted: 02 Feb 2018, 20:47
by bigbomber
erapip wrote: ↑02 Feb 2018, 19:42
[quote=bigbomber post_id=1093 time=1517591628
Thanks for reply.
About projector, I don't know a suitable one. All I know need modifications. I'm developing an application to solve the problem on software side.
About david v4. I have its SDK. For developing my app I use it. But the final version works for all HP versions.
what is the resolution of your IDS camera? Can you get well alignment using them as well as Nikon?
Erapip can you take a photo of your calib panel by a high quality camera (dslr if possible). I want to check it.
But resolution should not exceed 6MPixel.
The photo should be like when you want calibrate your scanner. Calib panel fill photo area. And in enough light. Projector is not needed.
Thanks for your help.
Posted: 02 Feb 2018, 20:50
by bigbomber
lovebay1 wrote: ↑02 Feb 2018, 20:10
Not correct. rms error you see is the projector error.
Look at my sent photo where I was looking for.
Posted: 02 Feb 2018, 21:37
"Erapip can you take a photo of your calib panel by a high quality camera (dslr if possible). I want to check it.
But resolution should not exceed 6MPixel."
Hi BigBomber,
I would like you to check my 220 mm panel. I'll appreciate.
Is the same panel I used in the second test I posted in our previous discussion. I double checked it and it does not seems so bad in terms of dot precision.
I'm waiting for some "Arca style" stuff in order to made my setup look more professional.
I hope results will improve too.
