New DIY turntable
New DIY turntable
Post by martan »
I made the openscan turntable earlier in this year. Fun to build but not much use for me....
What I have missed for a long time is a slightly larger turntable that can handle a lite more weight.
I looked in the garage what I had and designed with the parts I found. Cost was close to zero.
Some 3D-printed parts and the plate from the "IKEA Snurra" . Arduino Uno with Stepper Shield.
It works fine :-)
Concept:
(https://sites.google.com/site/janbeck/3 ... for-david4)
Re: New DIY turntable
Clean and elegant!
As usual :-)
I'm waiting for a wheel bearing Hub to build my heavy duty turntable. They are cheap and can load more than I need.
things like this with two flanges:
https://www.alibaba.com/product-detail/ ... 84930.html
martan wrote: 03 Jun 2020, 19:22 I made the openscan turntable earlier in this year. Fun to build but not much use for me....
It works fine :-)
Concept:
Really nice. Did you 3D print the gears?
Post by martan »
Yes, the gears are printed.
If someone wants STL/STEP-files, just give me a shout. All is done quickly and very dirty :lol:
Rain today. Wasn't really plesed with the motion - it felt a bit jerky.
The stepper-driver from the Openscan Project was really smooth so I took the circuitboard from this.
Adjusted the code slightly and made sure that I got 18 degrees between scans. It suceeded I think.
@Mading, using a wheel bearing from a car is brilliant!
For cylindrical or repeating elements - a turntable with an exact angle of rotation is a very useful thing.
P.S. In my first table (from the Ciclop laser scanner), a bearing 16014 was used, with an inner diameter of 70 mm and an outer diameter of 110 mm
bearing 16014
bearing 16014
P.P.S. Unfortunately, I can’t use the new table from RangeVision yet, because the program has not yet implemented support for my cameras.
martan wrote: 06 Jun 2020, 15:14 Yes, the gears are printed.
I'm really lazy when it comes to draw gears.
I was supposed to draw timing belt gears to couple with the wheel bearing, but everything is in the "to-do-list".
Post by martan »
My CAD-program made the gears for me.... a few clicks away.
Another solution is to download models from solidcomponents.com for example. I know Mädler has a complete-CAD-catolog...
https://www.maedler.de/product/1643/zah ... d-zubehoer
@ OBNRacerMan, that looked neat indeed :-)
martan wrote: 06 Jun 2020, 19:49 Another solution is to download models from solidcomponents.com for example. I know Mädler has a complete-CAD-catolog...
Thanks for the suggestion. I'm a long time basic Rhino user. Never put the effort on scripts or GH.
Yes, OBNRacerMan did a great job!
Hi Martan,
Would you please share the cad files for this project?
Post by martan »
Alonso wrote: 13 Dec 2020, 20:21 Hi Martan,
Sure!
What format do you want?
