Can I use these camera in HP and Flex in dual-camera-mode? isn't there any problem with them?
Isn't there any problem with setting and etc?
I don't think anyone can give an exact answer to these cameras ... they are of little interest to anyone in general ... these are extremely slow cameras that produce 7fps since use an external USB2.0 interface.
thanks for description.OBNRacerMan wrote: ↑24 Jan 2021, 10:11 I don't think anyone can give an exact answer to these cameras ... they are of little interest to anyone in general ... these are extremely slow cameras that produce 7fps since use an external USB2.0 interface.
Personally, I assume that they will not be visible in Flexscan3D, because (according to their description) they use the same API as MER-630, which are also not visible in that program.
There are also big doubts about their applicability with the Rangevision program ... but perhaps something could have happened (I know that USB2.0 cameras work there for sure - Toupcam UCMOS3100KPA (1/2", 3.1MP / 8fps) and UCMOS5100KPA (1/2.5", 5.1MP / 7fps))
As for the work in HP3DScan - there is some hope that they will be able to work there ...
In this case, buying such cameras you will act at your own peril and risk ... as a "pioneer"
According to mading flexscan can't see Daheng camera.bigbomber wrote: ↑24 Jan 2021, 13:43 thanks for description.
in the forum you told that there is a driver which allow to work with Daheng cameras and HP software in dual-camera-mode. can I know does it works with Flex or not? and also does does it work with Hp perfectly or there are some minor problems with HP software too?
Check this topic: viewtopic.php?f=16&t=2359
