New 280mm Panels
New 280mm Panels
Started making a new set of 280mm panels today. I wanted to try to improve over my previous 300mm panels that were made on a vinyl cutter. The weakest part of this was that I had to hand register the cut vinyl dots by lining up registration marks. Not very accurate. this time I'm printing both panels as one piece and the cutting then apart. this should be a big improvement in skew and alignment. I stuffed a sharpie in to the vinyl cutter and turned it into a plotter. heres how it worked:
https://youtu.be/0XzSlNkpfyU
