Cleaning metal surfaces with marking laser ...
Discussions about 3D-Printing, CNC-Milling, etc.
VDX
Post by VDX »
Hi All,
... after some marking and engraving, I've tested stripping black paint (development for cleaning metal surfaces):
https://vimeo.com/210773147
The result: - on the left a black tile -- on the right the black painted aluminum sheet (Dibond):
Viktor
Viktor
Re: Cleaning metal surfaces with marking laser ...
Can you give more details about the laser you are using? I have wanted a fiber laser for a long time to mark Stainless parts I make. However commercial fiber lasers are all too expensive to justify the cost. Did you build the one you are using?
VDX
Post by VDX »
... this was made with an old IPG YLM-60 type - an 60 Watts CW-fiberlaser with some problem to shut down completely when deactivated (the single spot visible between the jobs).
The previous videos were made with a 120W-type with only 3 of the 4 power-banks running, so 85 Watts maximal:
https://vimeo.com/207474893
https://vimeo.com/207440970
Will modify the prototype for a pulsed fiber-laser with 16 Watts averaged (maybe 100 Kilowatts peak power), what should give a better engraving result.
This are old "outsourced" units, I've got in exchange for other parts or service -- but we want to order a modern pulsed 20Watt-type soon, so should be running in common mode mid to end of April ...
Viktor
Viktor
VDX
Post by VDX »
... I've actually assembled the "serious" marking laser with a 20Watt (averaged) pulse-fiber-laser and did some testing on different materials.
Here are some videos of the housing and engraving on metal:
https://vimeo.com/214409447
https://vimeo.com/214745770
https://vimeo.com/215431737
... and here some of the results:
... the last image is something "historical" - I've found an old test sample of bitmap-engraving with my first CNC-mill and a self-written CAD/CAM-program on an Atari-ST from 1987 ... and used the back side for a laser-test -- so it's showing exactly 30 years difference in the "state of technology" ;)
Viktor
VDX
Post by VDX »
... this will be one of the "give-aways" on next exhibition in Juny ;)
Viktor
Cool :D I'm surprised, you are able to focus a high power laser so fine. no idea if this is something special ;) Anyway the results just look great!
VDX
Post by VDX »
... this is a common setup designed for a spot diameter of 30 microns, so not really special ;)
In past I've got 30 microns too with a 60 Watt NdYAG and 20 microns with a diode-pumped 20 Watt-disk-laser.
If I'll want a finer spot, this is possible with a beam-expander - have some with 2:1 or 4:1 ratio, so smallest possible spot diameters of 10 microns would be possible too.
Even finer details are possible with an Excimer-laser (did some laser-worx with sub-micron accuracy) ... but this type of laser is much too big for my basement :? ;)
Viktor
Viktor
VDX
Post by VDX »
... here's a video showing the engraving+cutting of some smaller tags - https://vimeo.com/216584306
- and the reslults:
Viktor
Are these machines you or your company sell or plan to sell?
VDX
Post by VDX »
... the last machine with the 20Watt-pulse-fiberlaser in the "white-blueish" housing is the prototype, I've developed for my company, which is planned to be selled in this size or slightly smaller, with some minor changes/updates.
I'll present it on the next exhibition(s), and then it's again at home as my "personal work-horse" and for testing "difficult" materials ;)
The previously posted images and videos were made with some CW-fiberlasers, which I've got/collected in the last 5 years in exchange for some of my old "gear" or private developments ...
Viktor
Viktor
